Failed simulation
Hi
I have a naïve question regarding this same issue. I am running a basic daylight factor simulation as my first experiment with Pollination. I am facing the grid related error which can be found here https://app.pollination.cloud/projects/amanjayedi/experiment1/jobs/5d819871-3444-4745-a40e-1f5726b3a42c
Is there something am I missing while modeling or computing?
Aman
Hi @amanjayedi,
You might want to check whether you have grids in your model. I looked at your model and it does not seem to have grids.
What @devang said! You can add sensor grids to your model using the Ladybug Tools Grasshopper plugin or the Pollination Rhino plugin.
Thanks a lot! :grinning:
Aman
Hi @amanjayedi :wave:
I just noticed that the service that helps display step logs had a fault in it which is why there were no logs to help you understand what had happened. I am in the process of implementing a fix which should make it easier for you to understand why steps are failing.
It should be ready within a couple of hours :raised_hands:
