Hello @mostapha
I’m trying to push a new construction from GH to Rhino and I get ‘failed to bake’ error.
The exact same command used to work a while ago, could it be a version thing?
Best,
Olivier
Hello @mostapha
Best,
Olivier
Hi @olivierdambron, sorry about that. Can you share a minimum example with us to recreate the issue? Thanks!
@mostapha no worries, here is a gh file with the relevant part.
Push construction.gh (39.4 KB)
Let me know if you can recreate it with this
Hi @olivierdambron, sorry for the issue. I just checked your file, and I can recreate the issue. I am looking into it now.
Ok, I have just fixed the issue and am building a new version of installer now. Will sent you via private message once it is ready.
Thank you so much, really appreciate it!!
