When loading GH I’m receiving the following error:
Priority: AssemblyPriority
Failed to find Pollination.RH assembly
ArgumentException
Any ideas? I have the GH ribbon present:
ArgumentException
Hi @furtonb,
This is a known issue in the older version.
Please update to the newest version, or run the “Pollination” command before opening the GH.
What @mingbo said!
To add more context here, a few of the Grasshopper plugins need the Pollination Rhino library to be loaded first. By running the Pollination command in Rhino once you will ensure that the DLLs are being loaded before opening Grasshopper.
