Can anyone tell me whether they can use PO_GenRoomPerimeters function inside Rhino plug-in PO.V1.52.12.0 (Oct 07, 2024) ?
I also give it a try with simple box model but didnt work either.
Levent
Levent
Hi @hlkocalioglu, I can recreate this issue on my side.
I am looking into it now.
Ok, this command is running some Python code for the core logic, and I know there are a lot of updates on this to support the Model Editor.
Hi @chriswmackey, could you remind me if you have made a single command/function for creating perimeters from floor geometry? I think this is a good opportunity to update this command to use the latest code you have been working on.
Thanks, @mingbo .
I remember that this is one of those things where we talked about giving you a simple, stable function to call so that you don’t need to have a bunch of Python code on your end. It looks like I added such a function 2 months ago that does this exactly:
You can see that it’s implemented in the CLI so it should work just like all of the other functions you are using for the exporters.
Thank you @chriswmackey, yes, that’s what I remembered, but somehow, I couldn’t find where the code is.
I am updating this now, and will keep you posted.
This should be fixed in this PR fix(core): update core for fixing PO_GenRoomPerimeters by MingboPeng · Pull Request #1208 · pollination/rhino-plugin
This should be fixed in the latest release v1.52.19
