Grasshopper Plugin in R8
I am having issues with Honeybee in R8 after running the Grasshopper Plugin installer. Everything seems to install correctly and the tabs show up in GH. Components from the Ladybug tab can be dropped on the canvas without issue, but as soon as I drop a Honeybee component on the canvas, it freezes and Rhino/GH crash without warning. Any ideas of things I could try to remedy this?
I don’t have issues running it in R7.
Hi @jroth, and welcome to the forum! This is most likely an issue with the Grasshopper/Rhino itself and not the Honeybee components. Can you try this script?
test-uuid.gh (9.2 KB)
If this script crashes Rhino, then you should check this discussion.
That did the trick, thank you!
