Help: After installing Ladybug Tools, an error occurs when opening Grasshopper. What could be the cause?
Failed to load the file or assembly “System.ComponentModel.Annotations, Version=4.2.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a” or one of its dependencies. The specified file could not be found. {FileNotFoundException}
Hi @z-liuziyan, welcome to the forum! Can you follow the suggestion here and use the Rhino plugin? It has fixed similar issues for other users.
See this update:
