Maybe it doesn’t work in this application, but I have the hole limit set to 20 ft2, and I am still getting column holes. In this case there is a room bounding wall element around it.
Hi @crduggin, the holes area filter only works for cases where the hole is fully bound inside the room. For the cases, of setbacks on the edge of the room try using the Short Segment Dist. input.
It removes all the edges that are shorter than the input distance. We have a similar command in Rhino, with a higher level of control.
