Hi @mingbo,
I have tried to create a ground source heatpump system and a parallel working ASHP and it worked most of the time with a radiant system.
Then I realized that it has good results but maybe it is not working optimal, so I have set an availibility manager at the Hot water loop of the GSHP loop at 0.9 (90% of the time whole year) but than I got an error massage sometimes that it is not correct and I have a typo somewhere. When I disconnected the availability manager the error for bad_weak ptr showed up not so often.
I tried to set an availability manager to the ASHP loop also but it did not help.
Why am I getting sometimes this error message for bad or weak ptr, and sometimes for protected memory partition?
Has my model too much floor space? ( about 25000m2)
I have also tried with different geometry with about a 1000m2 and I got the same error massages.
