Hi folks,
Sorry if this is a silly question, but I’m searched and searched and can’t find the answer.
I’m looking to access the ‘results’ data from an annual daylight simulation so I can do some manual post-processing.
From this post, it seems I need access to the annual-daylight.full recipe, but it doesn’t show when I search recipes and I’m hoping there’s an easier way to integrate it without going through the DSL process.
Any ideas?
-db
Hi @davidbarker, welcome to the forum!
Here is an example using the Pollination Grasshopper Plugin. You can also go to the web platform (or use the Pollination Rhino Plugin) and add the -full recipe to the project.
What post-processing do you want to do? I am mainly curious to know if it makes sense to add it to honeybee-radiance-postprocess or if it warrants a separate recipe in the future.
Hi @davidbarker,
What @mikkel said is the better way of doing it.
If you are running the study under your personal account, not an organization, it added the recipe automatically for you. In this case, you can right click on the component and edit the tag manually.
