I have a garage with a mesh material as the exterior wall - how can I draw a hole using pollination in rhino?
Hi @kbren,
Are you trying to create a shade with holes in front of the wall? Or are you trying to create a hole inside the wall instead of a window?
The second one is not possible to do in Pollination/EnergyPlus models. You should create it as a window and change it to a hole in IES VE.
There are different ways to do the first one. Can you provide a bit more information? Thanks.
got it! yes I am looking to create a hole inside the wall instead of a window. I’ll do it in IES VE! Thank you.
