How do I update my Rhino Plugin. I am unable to find the option to draw rooms in the Rhino Plugin
Hi @farhan, you can download a latest version of the Rhino plugin from here: https://app.pollination.cloud/cad-plugins
I need more information to be able to help you with this part. Is it because you can’t find the UI or the command doesn’t work? The command is PO_AddRooms
PO_Drawrooms. The command does not appear in the Rhino command line.
Hi @farhan
Could you check Rhino’s plugin manager to see if the Pollination plugin is loaded?
If it is loaded, could you please take a screenshot of the about dialog by using the command PO_PluginInfo?
