How to "add" recipes to an account
I want to be able to access the standard recipes (the ones that are shared in our “demo” folders) for my organisation’s account, but none are showing up:
How do I make them available?
Note: Recipes should be added to each project not the account.
Here is how you can add a recipe to a project:
  1. Go to project page. If you are an admin of the project you will see the Settings tab.
  2. Under Settings tab click on Recipes.
  3. Select a Recipe from the recipe list by typing the name of the recipe.
  4. If you want to use a specific tag, then select the tag - otherwise leave it to Any and press Add.
  5. You should see the recipe added to the list of the recipes under your project.
Now you should be able to access the recipe for all the Jobs in this project. :rocket:
