Hello! I have a question: I use the Pollination plugin linked to Rhino for modeling. However, I would like to know if it’s possible to automatically link the renaming of termozones in the Pollination panel with the layers in the Rhino panel.
If I understand correctly, you are looking for a solution to automatically use the name of the Rhino layers for naming the rooms. If that’s the case, you should check the PO_AddRoomsByLayer command.
Here is more information about the command.
