wxcchuck
(C X W)
January 26, 2023, 12:38pm
1
Hi Chris,
Thank you for sharing the .gh file.
I was trying to use it for TM59 analysis, but I can’t seem to access the recipe from your project.
I try to ‘Setup run’ to select the recipe from my ‘own’ project - but it is not in the list.
Would you help resolve this issue please?
many thanks!!
wxcchuck
(C X W)
January 26, 2023, 1:09pm
3
Just an updated:
I have managed to add the recipe (custom-energy-sim, owned by ladybug-tools) from Pollination’s web platform.
Tried to run again, but error at ‘Load Assets’ component
mostapha
(Mostapha)
January 26, 2023, 4:01pm
4
Hi, @wxcchuck - It is because the simulation is failing on Pollination. You can see the error file here .
wxcchuck
(C X W)
January 26, 2023, 4:37pm
5
Hi mostapha,
Thanks for responding
The error seems to be non-planar faces?
I just tried to run the same recipe on a much simpler room/model, the run is successful Pollination Cloud App
but there is no output from the .sql file (even though it appears to be >1MB)?
many thanks!
mostapha
(Mostapha)
January 26, 2023, 5:32pm
6
From what I see You haven’t asked for those outputs in your simulation.
Is there a reason that you are
You may want to use the annual-energy-use recipe instead which already has most of the default values set for you.
wxcchuck
(C X W)
January 26, 2023, 8:17pm
7
I think you are right…
I forgot to toggle this to ‘true’ …
wxcchuck
(C X W)
January 26, 2023, 8:24pm
8
Another issue is I can’t seem to find ‘bedroom’ program to assign to HB rooms, which results in incorrect filtering of data…
I have chosen the closest ‘apartment’ program for the purpose of the analysis - it gives results but I am not sure if I got it right… will try the ‘annual-energy-use’ recipe as you have suggested above
wxcchuck
(C X W)
January 28, 2023, 2:41pm
9
another update here
I ran into an issue when importing different weather files from 1)_URL and 2)local file.
the first method runs the simulation successfully ( 1b889215 )
but the 2nd results in .zip file when it should be a .sql file out of the ‘Load Asset’ component ( **546c032e **)
Any lead would be appreciated!
230126_TM59_XW.gh (748.5 KB)
Hey @wxcchuck ,
Your Grasshopper file has a lot in it that is not needed to download the results but I don’t have any issues downloading the SQL for that study when I do it with the Pollination components:
download_results.gh (9.6 KB)
