How to draw skylights
I want to draw skylights manually. I can draw apertures to walls by PO_DrawApertures, but this command is not suitable for drawing skylights to roofs. PO_AddSkylightsByRatio does not allow manual drawing. What is the easiest way to draw skylights to roofs manually? Can we use a new command PO_DrawSkylights in the future?
Hi @keigonomura,
In Pollination, a skylight is an aperture that belongs to a roof. You can use the same commands to add an aperture to a roof. Here is a short recording that shows using PO_AddAperture and PO_DrawApertures commands.
I’m not sure why you think the command is not suitable. Did you make sure that the mode is set to ElevationPlan so you can draw on the face directly?
@mostapha Thanks for your reply. I got it. I need to change the mode from FloorPlan to ElevationPlan, which is not mentioned in the tutorial video.
