Thank you for replying so quickly. I have already checked out the -viz version of the recipe.
The visualization file ( vtkjs ) only has the GA data mounted on it.
I was wondering if it can also get the DGP data mounted so that the same can also be viewed on the App when you select the date and time as an input from the user.
currently I am able to do this in grasshopper by selecting the HOY in HB annual average values component and passing the values of the selected hour to the LB Spatial Map as shown in the image below.
Hi @anujm1ttal! Thank you for the clarification. The hourly visualization doesn’t come by default but you should be able to create these visualizations on the fly in the app. Let me discuss this with @devang and get back to you about the best approach. What is your end goal for this visualization? Are you including it in a report? Is it for sharing the results with a customer or internally? Do you need it for a single day at a time?
So the goal is to use this app to make it easy for the team to figure out the worst possible scenarios.
It is for internal use at the moment, just to test.
Either a single day or Hourly would be okay. I am trying to figure out how to mount the hourly data in the App.
Thanks @devang
Big thanks for the script. I went much deeper into the honeybee_vtk library than ever before to understand the code.
This works perfectly to what I was looking for and I have been playing with the code a bit.
I have a few questions regarding the folder structure.
I am adding the results_folder_path and target_folder_path as an input to the app.
results_folder_path = st.text_input( label = ‘Enter the results folder path’, value = ’ ’ )
target_folder_path = st.text_input( label = ‘Enter the target folder path’, value = ’ ’ )
When I run the app, I can see that it generates the following in the specified target_folder_path
Although, its not able to read the grids_info.json from this path and i get this error
When I change the target_folder_path to Path(‘data’), it works fine.
target_folder_path = Path(‘data’)
and I can see that it generated the same information in the data folder.
I am not sure why it is not reading the grids_info.json from the specified target_folder_path.
Please let me know if you have any suggestions.
Thanks
@anujm1ttal,
you might want to update the write_config function. You’d see that path to the folder is hard coded as “data”. I believe that’s the likely culprit. This script was hurriedly put together so you should look forward to making such tweaks.
Good to know it helped @anujm1ttal. We would appreciate it if you could share on LinkedIn when your app is finished and it is a public app. If it’s not public then perhaps sharing your experience developing the app will also help.
