Including the LBT sample files in the installer
Hello -
Are LBT .gh sample files downloaded with single click Rhino installer (which also installs latest LBT components)?
Or should users still download separately from:
Best,
Victor
Hey, @victorbrac! Thank you for the suggestion. I agree that this can be a helpful addition but with the current speed of our development, it is also very high risk. Until we can find a way to automatically test and update the sample files we will end up with sample files that will not work right away.
What are your thoughts on this, @chriswmackey?
We make so few breaking changes on the Grasshopper plugin these days that I think the risk is pretty low. As long as the core libraries and simulation engines are correctly coordinated in the installation, the Grasshopper components can usually all be from the last stable release and still work correctly (they might just lack a new input or output that’s been added or something like that).
So I think we can probably include the Grasshopper samples in the installer without issues.
Hi @victorbrac, This one took us longer than it should have, but we finally have it.
Starting from v1.52.20 the latest version of the sample files from this repository is packaged with the Pollination Rhino installers.
As a bonus, we/@mingbo also added a component to load them without going to the folder. You can also use the component to open other Grasshopper files from a local folder.
The component is under Ladybug’s Extras tab.
That is so helpful for newbies! Thanks for this update!
Hi @mostapha @mingbo ,
This is a great component. Like it a lot!!
-A.
