Hello all
tried to install Version=0.144.4.0. It didn’t finish.
The plugin seems to work afterwards, at least a check of an elder model is working. Else I don’t know yet.
Hello all
Hi @martin6, from the screenshot it looks like it’s the grasshopper installer. From your tag, it should be the rhino installer. Can you clarify which one you’re trying to use? I can do a check on my end.
You are right @mostapha it was the Grasshopper Plugin, but it’s almost the same with the Rhino Plugin.
when I hit ignore
it states successful install
Hi @martin6 could you please try the latest version 0.148.18?
I tried it on my side and both of the latest versions work on my side with no issues. @martin6 let us know if you’re still having issues with the installer.
Hi @martin6,
Could you try to run the following command manually to see what’s the real error?
"C:\Program Files\ladybug_tools\python\python.exe" "C:\Program Files\temp\setupPlugin.py" install
Hi @mingbo
C:\Program Files\ladybug_tools\python\python.exe: can’t open file ‘C:\Program Files\temp\setupPlugin.py’: [Errno 2] No such file or directory
Done works with latest installer
