Interior walls are being treated like exterior
Hi! I was importing rooms from Revit to pollination and the boundary conditions and when I run the model report everything seems fine. However, when I highlight the exterior walls all the walls are highlighted. How can I fix this?
Hi @cemresonmez,
Did you run the solve adjacency command between the rooms?
