Intersections in IESve
It seems like my model is validated in pollination. However, when I run model report in IESve I am getting many intersections and zero volumes.
Hi @cemresonmez,
This should not be happening. When you ran the validation command, did you have all the levels visible? Is the intersection between the rooms on the same level or the rooms between different levels?
I know I will sound like a broken record, but if you can share the PoMF with me privately, we can resolve all these issues together in a matter of minutes. Without knowing the specifics about your error, it is very hard if not impossible to help you effectively. We can also plan for a call to share your screen and help you through the steps. I already sent you a private message. Thanks!
