Invalid Authorization when trying to activate the Rhino licence
Hi, I am having issue activating the license in Rhino. It gives me the following error: Invalid Authorization! Error calling GetMe: {“detail”:“Not authenticated”}.
Can I know what might be the issue and what is the solution to the problem?
Hi @ricjoseph,
Most likely this is because you’re using an older version of the Rhino/Revit plugin. See here:
Try to download and install the latest version and that should resolve the problem.
Also having this issue, downloading the latest Rhino plugin to see if that resolves the issue.
After downloading the latest version i can confirm the fix. Thanks all.
