Looks like the schedule from CSV file does not work with Pollination when validating the model. Will this eventually be available?
Hi @marentette external csv file is not supported with the Pollination workflow. If you want to run it locally, you can save the osm file first and then add the IronbugHVAC to osm file.
Thanks @mingbo. Will this eventually be added to the Pollination workflow?
Hi @marentette i think I have an idea of how to implement the scheduleFile for the Pollination. I will keep you posted
Hi @marentette, I just updated Ironbug to support ScheduleFile with the Pollination. You should be able to get the latest version in about an hour from here.
