As the title says. Thanks~
Hi @youknowleft! Can you be more specific? Do you have a sample job on Pollination that you can use as an example?
Hi mostapha,
Sorry, my sample is too complex as it is not easy to show here. I’m not sure whether only one result can be extracted one time. If I want to get all the result of parametric runs, I have to give the index manually one by one, right? As I connect pollination with my optimization control, there are always some invalid models so I don’t know exactly how many valid results I can obtain. Thus, I need a method that can automatically extract all the valid results.
Hi @youknowleft, have you seen this discussion:
Thanks, Mostapha. I’ve seen this discussion, and my problem is resolved.
