Issue exporting rooms from revit
Hi all. I am facing an error while creating rooms. It doesn’t define the error. I am attaching a snapshot below
Hi @asisnath - did you check the logs? Do you see any errors there? Since all the rooms are failing it is probably something substantial about the model or the Revit plugin.
Hi @mostapha. How can I check that in Revit plugin?
Click on About and you should see the path to the log file:
It is at %appdata%\pollination\logs\Debug.log. In the near future, we will add a button so you don’t have to do this.
This is the log file
Debug.log (1.2 MB)
Thanks! For some reason, it is failing to create the Spatial Space from the Revit model
2023-09-06 20:00:04.3875|FATAL|pollination_logger|System.NullReferenceException: Object reference not set to an instance of an object.
   at Pollination.Revit.Schemas.Room2D..ctor(SpatialElement e, List`1& messages)
   at Pollination.Revit.CreateModel.Wrappers.SpatialObjectWrapper..ctor(SpatialElement e, Boolean isSelectionWrapper, Boolean isFloorToCeilingHeightOverriden, String displayFloorToCeilingHeight)
   at Pollination.Revit.CreateModel.CreateModelRequestHandler.GetSpatialObjects(UIApplication app)|System.NullReferenceException: Object reference not set to an instance of an object.
2023-09-06 20:00:04.3875|INFO|pollination_logger|Failed to parse WC B8 120. It will be skipped.|
I’ll document this for @ksobon with your model. Can you tell me which version of the Revit is used for this project?
Revit 2024.1 version
OK. That might be it! We haven’t tested Revit 2024 enough to make it official. I’ll keep you posted!
