Can I use the pollination plugin to extrude spaces and export as a gem to REVIT? I have the spaces created and see the spaces option but there’s an issue with exporting gem files. Not sure if it is because of the spaces option selected. I do see the preview of the model though.
Hi @harshongole,
Yes. You should be able to export spaces from Revit. Can you provide me with more information? Do you see the space count to be more than 0? If you don’t see them, then you may have selected the wrong phase in step 1.
If that is not the source of the issue, I will need more information. Can you share the file with us? You can use a private message to share the model or more information if you don’t want to share them publicly.
The space count is not 0. I have selected phases with spaces. I have re-opened the model and seems to be working now. Thank you for the input!
Hi @harshongole, I’m glad that the problem was resolved. Let us know if you have any other questions. Thanks!
