@mostapha I managed to solve all the issues following your inputs. The only issue that I am still not able to solve regards the “Missing Adjecency” of a couple of doors, I tried to use PO_MatchChildGeometry as you suggested but I am sruggling to making it work… I am missing some steps when it comes to select the source and guide object. I tried to look on the guide too but I couldn’t find that many additional info on that command. Also to Solve Adjecency seems not to work in this case…
Would you happen to know what’s going on here? or what would be the best procedure to solve this?
I made a video recording of the validation issues:
Hi Mingbo, this is a topic that I can use your help with to understand what is the recommended workflow. This is the same model that I documented on Basecamp: Basecamp Log In
