Ever since installing Pollination I get this popup whenever I open grasshopper. I’ve been hitting “Skip All” and nothing is breaking, but it’s getting really annoying that this pops up every time and I’d like to fix it. I imagine I can go in and delete one of the files, but I don’t know which one I should delete and if that is even the right way to go about solving the problem. What’s the best way to fix this?
Hi @elpresser, this is happening because the older installation files haven’t been removed. Go ahead and manually remove the files under the roaming folder like this one that you see in the error message.
