Hi!
In the Leed Daylight Option Two recipe, is it possible to obtain an .html file (example attached) with the visualization of the result in the VisualizationSet format?
Hi, @isabellapsbarros,
Yes. Try clicking on the HTML txt on the visualization button and it will download an HTML version of the screenshot that you shared.
What @mostapha said is correct, however, I can see that the recipe is not creating the visualization, i.e., there is no recipe output for the visualization.
I will see if I can add it to the recipe tomorrow. Then you should be able to download an HTML version like Mostapha showed above.
If you use recipe version 0.3.8 you will get the visualization. There is an example in this study.
