LEED Recipe I Reporting as per IES LM-83-23
I am attempting to report results on a project using LEED Recipe I.
The documentation mentions to report it based on IES LM-83-23 which also has an example of a space by space daylight simulation report.
Would it be possible to also include sDA with blinds up and sDA with blinds down within the LEED recipe output?
Hi @pkhanchandani,
Yes, that is possible. I will try and get it added this week.
Hi @pkhanchandani,
Version 0.0.31 of the recipe should have these two values in the space-summary recipe output.
hi @mikkel, Many thanks for the update. I was just testing the Recipe. Was not sure how I can retrieve the data. Could you help me with how would I be able to access the same?
Hi @pkhanchandani,
I have added a handler to read the results in Grasshopper. Renamed to grid-summary. When running the recipe locally you also have to update your core libraries with LB Versioner or wait for a new Pollination installer. Otherwise the two new values will not show up in the recipe output.
Thanks Mikkel, might need to wait for the Pollination update! Will update here when I have tested a run.
