LEED Recipe to DaylightMetrics component (UDI)
Hello!
I am using the LEED daylighting recipe for a project where I would then also like to assess the Useful Daylight Illuminance (UDI). However I would like to to assess it also using the same blinds schedule as was used in the LEED recipe but I am having trouble converting the dynamic schedule when connecting it to the DaylightMetrics component
Would anyone have any advice on how to achieve this or on where I am going wrong?
Many thanks,
Pauline
Hi @pramos,
This is probably not supported because the recipe previously used a different method, where the schedules in the recipe were not the same as those from the HB Annual Daylight Metrics component.
I think what you’re asking is a great feature request – in fact, during post-processing in the recipe, the dynamic schedules are converted into data collections, so they’re already available at that stage.
Until this is added to the recipe as an output, you can use the small Python script in the attached file to convert the data collections to dynamic schedules.
data_collection_to_dyn_sch.gh (5.3 KB)
Hi @mikkel,
I have unfortunately not managed to get it to work using the script attached.
I was trying to connect the dynamic schedule output onto the HB Annual Daylight Metrics component but just got the following error:
1. Solution exception:Failed to compute annual daylight metrics.
Would you have any suggestions or perhaps I am missing a step?
Many thanks,
Pauline
Hi @pramos,
It is difficult to tell what the issue is from the error message. Are you able to share the model either here or in a private message?
