List Studies error
Hi, I have run numerous studies in pollination and have been using the “List Studies” component to retrieve these results with no issues in the past. This morning I have been trying to do this again, but I am met with the following error:
1. JSON integer 8632335625 is too large or small for an Int32. Path ‘resources[4].resources_duration.memory’, line 1, position 56251.
This is the error I receive soon after I connect to the project input, although I am using the same panel to feed into the input as I have been for the past week so am unsure why this is occuring.
Is anybody able to help with this issue?
Hi @rajath, are you using the latest version of the plugin? We fixed this issue a few months ago.
Hi @mostapha, I have just updated my Pollination to the latest version (VER 1.51.2.0), but this issue is still persisting :confused:
Thank you for checking, @rajath! I fixed the numbers manually for now, and I will have a closer look tomorrow. Can you give it a try and let me know if the issue is fixed?
Yes that worked, Thanks @mostapha!
Hi @mostapha ,
I am experiencing this issue once again -
I have checked and I am using the most up to date version of Pollination on my machine.
May I please have this fixed?
Thank you in advance
Hi @rajath, sorry about that. It should be fixed now.
Thanks @mostapha , it works :slight_smile:
We pushed a fix for the issue with the wrong large usage numbers. It should not happen in the future.
