I have loaded a 256 run simulation into the load runs component and it is causing GH to freeze. I have opened new solvers, re-loaded GH, and loaded in new instances of the component, but the same error crops up again and again. Not sure what I can do to fix this
Thank you for bringing this to our attention. Can you provide more information about the Job and the recipe that you used. Are you also trying to download the results at the same time?
Our server recently has an update for big parametric jobs (thanks @tyler), and your job’s status and all runs’ status are also updated if you refresh the site. If you try to reload them in GH, all runs’ assets should be able to be downloaded successfully. Please let us know if you have any questions or issues.
