Hi ALL,
I’m trying to make a annual daylight simulation with pollination both on Cloud and local machine.
Plumpton Aquatic Centre_Daylighting Level 02.hbjson (4.4 MB)
My file works well with Cloud simulation, however it just not able to run on my local machine, and 3hr used up only after a few runs. The following error appeared. Could you please help:
1. Traceback (most recent call last):
File "C:\Program Files\ladybug_tools\python\lib\runpy.py", line 196, in _run_module_as_main
return _run_code(code, main_globals, None,
File "C:\Program Files\ladybug_tools\python\lib\runpy.py", line 86, in _run_code
exec(code, run_globals)
File "C:\Program Files\ladybug_tools\python\Scripts\queenbee.exe\__main__.py", line 4, in <module>
File "C:\Program Files\ladybug_tools\python\lib\site-packages\queenbee\cli\__init__.py", line 13, in <module>
from .context import Context
File "C:\Program Files\ladybug_tools\python\lib\site-packages\queenbee\cli\context.py", line 5, in <module>
from pydantic import Field
File "pydantic\__init__.py", line 2, in init pydantic.__init__
ImportError: DLL load failed while importing dataclasses: Access is denied.
DA Local Machine Run Fail.gh (66.9 KB)
