Sketchup has a setting where you can make lines colored based on which axis they are parallel to. That way you dont accidentally draw a line that is 5 degrees from X-axis. It would be super helpful if pollination could also have a similar setting so I know everything is square.
Hi @eschwartz, thank you for the suggestion. We should be able to add this to the styling options.
@antonellodinunzio, you know SketchUp better than I do, but in case it is helpful here is a short video that shows the functionality.
We might want to group this with other color by
functionalities for lines like color by boundary condition to be able to quickly see the interior vs exterior walls without the need to do a 3D rendering.
Hi @eschwartz, the feature is now available in the latest release. ALT + O
highlights the non-orthogonal walls.
