Mirroring rooms does not take windows properly
Hi team,
I am trying to mirror a block of my model which has all doors and windows assigned, but when I try to mirror it, the door and windows don’t come along with their associated rooms, instead they stay on their primary location. Could you please suggest how this may be done?
Thanks
Hi @ishitasingh,
Did you make sure that the room selection mode is on? Do you see the windows and doors as part of the selection when you select the room? In my test, everything works as expected.
Hi Mostapha,
I tried it, could be because I do not create a copy? It works fine if a copy is created.
Thanks for the quick response. I was trying it by deleting the original but since creating a copy is working. I will do this way.
Thank you!
I see! That one is an issue. Thank you for posting the video. I’m going to assign this topic to Mingbo so he can investigate.
Thank you @ishitasingh for reporting this issue, I can confirm that the issue happens when the copy option is turned off with the mirror command. I will look into it.
