What’s the best way to deal with mismatched area adjacency? The error shows up when the solve adjacency command is run. Rebuilding the rooms and re-running the solve adjacency compounds additional errors.
I used the PO_AlignInPlan to align the wall, and then I used the PO_RebuildRooms to merge the faces, and remove the boundary condition, and the problem was resolved.
That said, the model needs some clean-up to align the lines between the floors to remove all the small edges that are created after solving adjacencies.
