I can’t find this in my Honeybee Recipes. Can someone tell me how to get this please?
Hi @pzarate, welcome to the forum.
This is not a Honeybee recipe component. You can use the Pollination Setup Runs component to get a recipe.
See the docs here:
And this video should help you to get started.
Thank you! Those resources were very helpful. I’m getting failed runs. What could be the issue? Pollination Cloud App
Hi @pzarate,
Is this still an issue? I see that you have ran several simulations successfully.
4 posts were split to a new topic: What is the correct recipe for calculating ASE?
I can check but Mikkel should already know the answer. Most likely you’re using the wrong tag.
