Why do I get this when I add an internal door to a room?
With other doors it works.
Pollination Rhino Plugin: 1.6.1.0 (01.08.2022)
Newtonsoft.Json.JsonSerializationException: Error converting value "sub-face" to type 'HoneybeeSchema.ObjectTypes'. Path 'errors[0].element_type', line 12, position 38. ---> System.ArgumentException: Requested value 'sub-face' was not found.
bei Newtonsoft.Json.Utilities.EnumUtils.ParseEnum(Type enumType, NamingStrategy namingStrategy, String value, Boolean disallowNumber)
bei Newtonsoft.Json.Converters.StringEnumConverter.ReadJson(JsonReader reader, Type objectType, Object existingValue, JsonSerializer serializer)
--- Ende der internen Ausnahmestapelüberwachung ---
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.DeserializeConvertable(JsonConverter converter, JsonReader reader, Type objectType, Object existingValue)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.SetPropertyValue(JsonProperty property, JsonConverter propertyConverter, JsonContainerContract containerContract, JsonProperty containerProperty, JsonReader reader, Object target)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateObject(Object newObject, JsonReader reader, JsonObjectContract contract, JsonProperty member, String id)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateObject(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateValueInternal(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, JsonContainerContract containerContract, JsonProperty containerMember, Object existingValue)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.PopulateList(IList list, JsonReader reader, JsonArrayContract contract, JsonProperty containerProperty, String id)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.CreateList(JsonReader reader, Type objectType, JsonContract contract, JsonProperty member, Object existingValue, String id)
bei Newtonsoft.Json.Serialization.JsonSerializerInternalReader.Deserialize(JsonReader reader, Type objectType, Boolean checkAdditionalContent)
bei Newtonsoft.Json.JsonSerializer.DeserializeInternal(JsonReader reader, Type objectType)
bei Newtonsoft.Json.JsonConvert.DeserializeObject(String value, Type type, JsonSerializerSettings settings)
bei Newtonsoft.Json.JsonConvert.DeserializeObject[T](String value, JsonSerializerSettings settings)
bei HoneybeeSchema.ValidationReport.FromJson(String json)
bei Core.Utility.ValidateModel(String hbJsonPath, ValidationReport& report)
bei Pollination.RH.RhinoCommands.PO_ValidateModel.RunCommand(RhinoDoc doc, RunMode mode)
