Modification of HBJSON Program Type and Comstruction Set in Grasshopper
Hey Guys,
I’m a uni student at UNSW undertaking a research project regarding Energy Simulations and the possibility of using a Pollination and Honeybee package to streamline traditional workflows.
I was wondering whether there is a grasshopper module that further deconstructs HB models more than just ‘DeconstructModel’. I was interested in modifying the HB room properties, more specific program type, HVAC settings and construction set of a JBJSON I have imported from Revit (thanks to pollination) into Grasshopper.
Hi @stefenon, Welcome to the forum.
Pollination Rhino plugin is fully compatible with Ladybug Tools Grasshopper plugins. You can simply use the Honeybee components to adjust the program type and HVAC settings after importing the rooms from Rhino to Grasshopper.
Hi @mostapha, thanks for the fast response!
What Honeybee components would you recommend using to adjust program type and HVAC settings after importing the rooms from HBJSON file?
i believe you should check the sample files from the food4rhino LBT package.
Look for the creating_programs and creating_materials GH files.
-A.
Perfect! Thank you both for the guidance.
