Most of the glazing not showing up in window/door preview
Hi there. I’m looking in the windows/doors menu and the preview is only showing a small number of the glazing/facade panels. The small number that I do see only show up if I select all of the families, and they don’t show up when I select only the family they belong to.
Is there anything I’ve missed? I’m open to having a call to discuss it further.
Thanks.
Hi @ladekoya, I sent you a private message to set up a call so I can help you.
This was happening because Pollination Revit plugin was only loading the files from the first linked model. It has been fixed and will not be an issue in the upcoming release of the Revit plugin.
hello, i have the same problem, can you help me. thank you
Hi @yazan,
I need more information to be able to help you. I suggest creating a new topic with a screenshot and more information including the version of the Pollination Revit plugin that you’re using.
