Hi there,
I am trying to assign vent control to rooms set up in pollination with their window opening properties defined in pollination. Is there a way to do this natively in pollination? If i do it in grasshopper then i am required to use a window opening component which will override the discharge coefficient /opening fraction and height etc. Has anyone found a workaround for this?
I know this issue us assigned to @mingbo but I figured I would just post the answer here.
If you use the PO_EditApertureProperties command or right-click on any Aperture selected in the tree view and select “Edit Properties”, this will bring up an interface where you can edit the attributes of the Aperture(s). You will see there is a “Ventilation” tab where you can assign a specific fraction of height operable and discharge coefficient just for the selected Aperture(s):
This way, you have a lot more control compared to what the Grasshopper components do and you can set the ventilation properties of each window separately.
Just make sure that you also right-click the parent room(s) in the tree view and select “Edit Properties” so that you can also set the ventilation controls on the room level. You’ll see there’s a “Controls” tab where you can specify the room setpoints at which the windows will open:
Only when you have set up both the opening properties on the Aperture level and the controls on the room level will you be able to run E+ simulations that include window opening.
