No sensor grids in the hbjson model
Hi, I am having some troubles with this problem: when i try to export the hbjson from revit it doesn’t export the sensor grid even if those are tilted into the selection menu, How can I solve this?
Thank you
Hi, @giacomobragadini - this looks like a bug. Can you provide more information so I can try to replicate the issue on my end?
  1. What is the version of the Revit plugin?
  2. What method are you using for geometry extraction? Detailed vs Extruded.
Hi i am using the revit plug in, the latest that you can download from the platform,
and i am using the detailed export since many of the recepy need the hbjson extend
This bug has been fixed in the latest release of the Revit plugin.
