Hello everyone,
I have a rhino 7 and when I installed the pollination it keeps showing me open rhino 3 times for rhino 6 and not showing anything.
What should I do?
Hello everyone,
What should I do?
Hi @snorouzi,
Can you try the PluginManager command in Rhino, and then search for Pollination? Do you see them on the list? Are they Loaded and Enabled?
If you see them but they are not enabled then try to load them manually by right-clicking on the line and selecting the Load plug-in option.
Hope it helps!
Hi Mostafa,
Thank you so much for your prompt response. I just did that and it worked.
Thank you
