OS/E+ Room Names
Hi All! New user here - so apologies if I am missing something. I’ve seen some past discussions about changing the room names such that they appear in the OS or E+ model as the Revit room name rather than a long string that isn’t easy to identify (specifically, I saw that there is PO_ResetIdentifier for the Pollination Rhino plug in). Is there a similar feature for the Revit plugin?
Hey @cio890 ,
We don’t currently have a workflow in the Revit plugin that does this but it’s a really good idea. Let me put together a reset_room_identifiers routine that we can run as part of the translation commands and then we’ll expose it as an option in the Revit plugin.
Thanks a lot for the response! I look forward to testing this in the near future.
Hi @cio890 ,
I am just letting you know that I have implemented the core library capabilities for exporting the OSM using the display names:
I have documented it for Konrad so that we can hopefully get it into the next Revit plugin release.
