Hi everyone,
I tried to test parametric runs by pollination. When the number of runs is less than 10, it can finish faster than local runs. But for more runs as blow (over 50 runs), it becomes very slow. Is this a normal case?
Bests,
Hi @youknowleft,
During the beta testing period every account has a limitation of executing 100 parallel tasks. When you run several jobs in parallel which triggers more than 100 tasks, the rest of the tasks will wait to be executed and that’s what results in the delay.
Also did you delete your project? I can seem to find the runs under your account to do a better inspection.
