I am using the PO_AlignToGrids command and when the face that is being aligned has a door or window the following error occurs:
If I remove the hosted element from the face the command works as expected. Is there a better way to do this?
Hi @marentette,
The command is being renamed to PO_AlignInPlan
and we have made a few improvements to it. Can you try to update your installation and try again?
If you can’t do that, can you provide a sample model for us to be able to recreate the issue? By default, it should align all the doors and apertures after aligning the walls.
Thanks.
@mostapha yep with the update it works!
