Hi @mostapha.
The PO_ModelEditor command is missing in my Rhino8.
It’s probably not interlinked, but when I try to load the .gem file into the Model Editor desktop app i get the following error in the log:
2025.09.29 11:05:45.636|error|import_file failed. Error message: Error: Traceback (most recent call last):
File “/lib/python312.zip/_pyodide/_base.py”, line 597, in eval_code_async
await CodeRunner(
File “/lib/python312.zip/_pyodide/_base.py”, line 411, in run_async
coroutine = eval(self.code, globals, locals)
File “”, line 55, in
File “”, line 42, in from_gem
File “/home/pyodide/honeybee_ies/reader.py”, line 493, in model_from_gem
parsed_objects = [_parse_gem_segment(segment) for segment in segments]
File “/home/pyodide/honeybee_ies/reader.py”, line 267, in _parse_gem_segment
gem_type = _gem_object_type(info=info, keyword=keyword)
File “/home/pyodide/honeybee_ies/reader.py”, line 27, in gem_object_type
type = int(re.findall(r’^TYPE\n(\d*)', info, re.MULTILINE)[0])
IndexError: list index out of range
Hi @mosti,
Try to right click and refresh the page. The Model Editor needs to download several libraries the first time.
Refresh what page? I cannot refresh the ModelEditor, that pops up from the PO_ModelEditor Command from Rhino. It remains blank.
Hi @mosti, sorry if I was not clear.
You actually can refresh the Model Editor page. It is using the same technology as a browser. Try to right click and you should see the option.
You can also select the Model Editor page and press Ctrl + R which does the same.
Issue was resolved. It was caused by company software management, which rolls out older versions of Pollination.
