Can this command be modified to support polylines as cutters?
For example, I’d like to cut out this corner of building but this requires use of polyline. I don’t see option to cut through space in for anything other than simple single line or planar cut. How should user make two cuts like this?
Oh cool, that worked! Couldn’t select polylines as cutter but draw polyline, then extrude curve then select in PO_SplitRoom command functions as workaround until polyline support is added.
