Pollinate: One or more errors occurred
I’ve been following along with Mostapha’s YouTube tutorials.
Running this definition in Pollination worked fine yesterday, but today I’m getting this error:
PC_daylight_factor.gh (75.6 KB)
I’m logged on
I also changed the Name and Subfolder inputs in case that was overwriting anything.
Hi @Max, Overwriting shouldn’t be a problem! Is it the same file from yesterday? Does the new simulation show up on Pollination? In case the file is from yesterday try to right click and log out and then log-in back.
cc: @Mingbo
Logging out and back in worked, thanks!
Thank you for the update @Max!
@Mingbo is there a better way to catch this error and report it to the user? Why does it even try to submit the Job is the log-in has been expired?
The error message should be caught in the logs. Plugin doesn’t know when the log-in is expired as long as Rhino isn’t closed. So it only know the issue when the plugin tries to talk to the server and the server complains.
I should be able to relay the real error message to UI. Issue created: https://github.com/pollination/rhino-plugin/issues/420
