Hello, I installed Pollination for Revit but after running Revit, there is no Add-in added. I also can’t see it in AppData on my disk, it has installed succesfully, but it is nowhere to find. Can’t find Pollination Manager as well.
I am trying the demo version - just so you know.
Hmm. If it is installed successfully, then you should see the files on the local drive. Do you happen to have an antivirus on your machine that might have removed the files from the local drive upon installation?
The addin file should be under C:\ProgramData\Autodesk\Revit\Addins\{Revit-Version} folder. For instance, if you are installing the plugin for Revit 2025 you should see it under C:\ProgramData\Autodesk\Revit\Addins\2025. Can you check and see if the Pollination.Revit.addin file exist in that folder?
